Home > Maintenance & Modifications > Re Engine System Fault
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Hi Lads
Couldn't seem to add this to my original post for some reason Confused Had a smoke test done on the Sport and all seems ok with Intercooler /hoses etc.
Had the Codes read again as below
P0405 Egr Sensor A circuit low Pending
P140A Egr Sensor C circuit low Intermittent
P0234 Turbo Overboost condition Pending
P132B Turbo Boost Control solenoid-circuit range/performance permanent.
P1335 Egr Throttle position sensor Min/Max stop performance Pending
P0404 Egr control circuit Range/Performance Pending.
Again I take it the EGR faults are due to these being blanked off and shouldn't be causing the Engine system or Special Programs Off faults. Would P132B point towards the Turbo Actuator Solenoid being faulty and could this cause the Limp Mode conditions. Can't remember if this can be changed seperately.
Cheers Jock Thumbs Up
Post #525435 Fri May 05 2017 9:37pm
Disco_Mikey
132B normally indicates a seized actuator, but you said it's free
It's not a boost leak, otherwise a smoke test would have shown that up
Beginning to look more and more like a faulty actuator, which comes as part of a new turbo...
EGR codes can be ignored if blanked Thumbs Up
Post #525436 Fri May 05 2017 10:05pm
Jock 77
Cheers Mike
Thanks again for the info. Have sent you a PM bud. Thumbs Up
Cheers Jock
Post #525438 Fri May 05 2017 10:18pm
Jock 77
Hi Lads
A quick update not sure if this makes any sense or not hopefully someone can help. Hadn't really noticed till now but these faults are still coming up when I have the car in auto and push it on ,but if I have the car in manual shift the fault doesn't appear to come up when I push it on. Will try more testing tomorrow and report further. Does anyone have any ideas regarding this.
Hope to get the car to Mikey later on in June , but my son is heading off with it next week and I wondered if there was anything else I could check before he goes after noticing this.
Thanks Jock Confused Thumbs Up
Post #526729 Wed May 24 2017 9:52pm
Johnski
Can't help with this fault, but I have a couple of engineers visiting me so I'll ask them for any ideas. John
Post #526732 Wed May 24 2017 10:02pm
Jock 77
Thanks John
Would be much appreciated.
Jock Thumbs Up
Post #526733 Wed May 24 2017 10:11pm
Johnski
Sorry for the delay Jock, one of them is looking into it, but had no idea or anything listed in his "idiot" fault guide as he called it.
There will be a delay unfortunately, as I've just changed hospitals once again. Sad Big Cry John
Post #527121 Tue May 30 2017 2:07pm
Jock 77
Re Engine Fault.
Hi John
Sorry for the late reply I was away last week and had no internet. Again thanks for the help much appreciated.
Cheers Jock
Post #527632 Mon Jun 05 2017 9:56am
