![]() | Home > Wheels & Tyres > Replace 1 or two? |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
IMO you can stick with replacing one and the same Conti tire. the AWD is not that sensitive RRS 3.0 SDV6 HSE Lux
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1550 ![]() ![]() ![]() |
I replaced a rear Pirelli with a puncture for a new one. I don't know how many miles the old rears had done but you can see a marked difference in the wear between the new and the old just by looking. I've had no issues with the difference in tread depth between the two rears so I think you'd be really unlucky to pick up an issue.
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
They're around £255 plus fitting (275/40r22) |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Might as well try just the one, should be fine being the same tyre and you'd hope a premium tyre would have relatively tight tolerance control from batch to batch.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 549 ![]() |
Buy one and use your unused spare on the back and make the part worn one your spare tyre... |
Unfortunately I don't have a full size spare - its one of those space saver style black wheels 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Arrrrr.....that won't work then! Just had the same predicament and fortunately I did have! Back to the drawing board! |
So, is another option to look for a full size wheel (here or on ebay) to use as a spare - if it will fit |
I'm happy to have the space saver, it will work on front or rear and this is the first car I have had in 6 years that has had a spare of any kind, the cars in between have had a 'repair' kit. Also with the running wheel/tyres being 22" I'm not sure that a full size spare will fit in the well. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Tim, I've got a 22" spare wheel in mine. |
Spent a morning touring the local tyre specialists and every one of them except one came up with the same comments -
