Home > Technical > Whining noise after switching off.
Eaters
Ok. When I switch off I hear a high pitched whining noise for about a minute or so. What is it? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #525173 Wed May 03 2017 4:13pm
Tim in Scotland
Turbos still spinning and cooling off? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #525174 Wed May 03 2017 4:26pm
Eaters
Hi Tim
Thanks for that. So are they powered (i.e. Electric?) once the engine is switched off (for cooling) or are they just winding down?
And is that a good thing? Or should I be trying to mitigate the length of time they whine? I already (normally) sit with the engine running for about a half a minute to a minute after a run even if I've not been aggressive on the throttle during the run.
Regards
Robin Robin
Gone:
MGZTT 190 2.5
Post #525175 Wed May 03 2017 4:39pm
Tim in Scotland
IIRC they will run on for a short spell to cool enough to prevent the oil frying onto the bearings however it is very good practice with a turbo engine not to come to a halt after a run and just switch off (and it doesn't matter if it is a petrol or diesel) for the longevity of the turbo bearings - the thing gets red hot in operation so some mechanical symphathy is necessary. The whine could also be the cooling fan for the engine running on too, but I know the noise that you mean but while it was very noticable on my previous RRS's and the FFRR's that I have run I never noticed it on either of the Evoques or the L494. Some turbos are water cooled and they make the same noise as the water still has to be circulated to disperse the heat. Not sure if it might not also be the intercooler also circulating cooling water through the system to also dissipate heat. And on some engines it can be the HP fuel pump still running........... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #525178 Wed May 03 2017 5:56pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Re: Whining noise after switching off.
I sometimes get that after a sprightly drive, I find it best just to wait it out and the wife quietens the whining down eventually... Laughing 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #525181 Wed May 03 2017 6:39pm
Eaters
Brave man to put that in writing Rolling with laughter Robin
Gone:
MGZTT 190 2.5
Post #525184 Wed May 03 2017 7:16pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Yes, never turn off the engine straight away after a hard drive, the spooling is still pumping oil in the turbos to ensure they are cooled and not Censored .
Those turbos spin at a very high rate and get very hot Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #525190 Wed May 03 2017 8:31pm
Eaters
Thanks for all the advice guys. I've uploaded a short video recording the sound and focussed in on where I think its coming from.
I've not noticed before but there's also a clicking sound immediately after shut down. It sounds like its supposed to be there but it would be interesting to know what it is. Robin
Gone:
MGZTT 190 2.5
Post #525336 Fri May 05 2017 7:57am
The clicking noise in the turbo VVT units opening the closing as a self test or to stop them sticking (and helps with oiling!)
My TDV6 also has the high pitch wine. Maybe the EGR C throttle body doing similar movements.
I wouldn't worry.
Certainly not the turbo's spinning down Rolling Eyes
Post #525366 Fri May 05 2017 12:11pm
garrycol
Australia
Yes sounds like the shutdown cycle of the EGRs. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #525370 Fri May 05 2017 12:19pm
always allow the turbo to cool down after a drive, especially a spirited one.
What I normally do (when driving on the highway), is to slow down during the last km to allow the turbo to cool down while there's still air flowing through, and then idle until the EGT falls below !60C. Usually happens by the time I stop, gather wallet, keys, etc.,
of course, this is in my Puma, where I have a madman fitted, not sure if that's possible on the RRS? --
Post #525371 Fri May 05 2017 12:19pm
Eaters
Great Thumbs Up
Sounds like its doing what it should and, as I do let it idle before turning off, I'm also doing what I should
No further problems... Shocked Whistle Robin
Gone:
MGZTT 190 2.5
Post #525397 Fri May 05 2017 3:54pm
