![]() | Home > Tips & Tricks > How to replace the front seat base foam |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
I have just ordered a foam seat base for my drivers seat, it was starting to sag on the right bolster. This excellent write up makes it look a fairly straightforward job.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Is it just the foam base you can buy or can you get the leather from the dealer also ? |
I just bought the foam, I will reuse the leather. There are a couple of LR leathers on ebay atm. |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
The seat foam and heater pad are about the same price, so around 50 or 60 Euro each. You can't see the eyes of the demon until him come callin' |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208 ![]() ![]() ![]() |
Great write up and "did" mine today, until I discovered I was shipped the wrong foam! Put the butchered seat back in until I get the right cushion this week...... 2018 Telsa MS
Alas, the new foam has arrived for me to complete the project Monday. 2018 Telsa MS
Cool, at least you know what you're doing now so should be a quick job |
Much better only 49k on the car yet this mod makes a nice difference to the bottom end.....I ended up using hog rings to attach the cover to the foam, nice and tidy. 2018 Telsa MS
Replaced my drivers seat foam today, I used cable ties to hold it all together. Took 2.5 hours, very pleased with the result
Nice one, makes a big difference. I just need to find the sweet spot of comfort with the seat adjustments.... 2018 Telsa MS
New drivers seat base foam installed and refitted to car. The creases in the leather are beginning to come out since I have thoroughly nourished it.
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
Can this how to be added into the definitive list of how to's sticky in the technical section? 2006 Java Black HST Supercharged |
HappyHammer Member Since: 24 Jan 2017 Location: Essex Posts: 59 ![]() ![]() ![]() |
I have the same, crumpled drivers seat bolster, issue.
This was very easy and have the hog ring tool if you need it. Putting the 4 bolts back in to hold the seat base in was frustrating, yet easily done. All told it will take an hour or so.
