![]() | Home > Maintenance & Modifications > Wishing my RRS sounded like an SVR! |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I too would like to hear of any good systems or mods that people have made to exhaust sound.
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 748 ![]() ![]() ![]() |
Just do a search on the forum here, both of you. There are even video clips of cars with sections of the stock exhaust replaced. What you are basically looking into is removing the centre muffler (or the front and centre muffler, if your local community consists of mostly deaf pensioners). Regards etc.,
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Note that the pops/bangs on overrun are artificially put into the engine map by SVR tuners, so you are not necessarily getting these in amount of an SVR. I rarely hear a pop/bang while changing gears or heavy braking in sport mode. Regards etc.,
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I've got a custom exhaust that has the centre 'Snail' resonator deleted and also both rear mufflers. It give a nice roar when you're rough and also when you start it, but when you're gentle it's pretty much as quiet as the stock exhaust. No real drone from the V8 other than when pulling up hill at around 30, and again at 60, but when cruising at these speeds it's fine.
Thanks Socast,
Yes, exactly. In most applications once you lift off the throttle, fuel delivery is cut, the injectors cease to work momentarily. In order to achieve the pop/bang effect, there is a different strategy, namely a small amount of fuel is still being injected, however it happens right when the exhaust valves are open, so the fuel burns downstream the exhaust system with pops and bangs. This is fairly easy to implement in direct injection engines and these tactics are widely used by performance divisions of most modern manufacturers. Here's the detailed explanation, please take note of slide 6 where this exact fueling strategy is described in regards of the SVR: https://www.topgear.com/car-news/top-gear-...nd-so-good Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Well I'm happy and surprised to be corrected haha.
Thanks for taking the time to do the videos Socast!!!
MILES better than my one!!! Here's resonator delete (x-pipe instead) only: I will delete the rears then... Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
It's the Ace pump, when I replaced it it was silent until oil from the reservoir reached it. I've had it to a specialist and even he's at a loss as to why it's doing it ![]() Have a look for the thread I started and you can see what I've done to try and rectify the fault.. I've got two pipes to replace and I will have then replaced the entire system (bar the sway bars which don't effect the noise). |
My system only has the front swirl/blend box, no x-pipe (I'm hoping it's in the blend box haha). ![]() |
TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93 ![]() ![]() ![]() |
I paid Ł450-Ł500 for a stainless exhaust, deleting the muffler and the 2 back boxes. Was from a powerflow place! 2006 Java Black HST Supercharged |
After reading all of this got mine booked in on Saturday with Style Dynamics who seem to have pretty good reviews.
