![]() | Home > General > Broken wire |
| Sharpy1980 Member Since: 24 Sep 2016 Location: Kent Posts: 98
That's the pressure sensor for the A/C to shut the a/c pump down when the gas pressure is low to protect the pump as the gas carries the lubricant for the system it also shuts the pump down if you get a fault that causes excessive pressure in the system. I guess your a/c isn't working at the min? Clickadeeclick |
| Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310
OK, thanks. What are we looking at in terms of a fix, connecting the 2 parts of the cable back together or a new cable?
| geoffsnook Member Since: 19 Nov 2016 Location: cardiff Posts: 1702
If you can fix it then give it a go |
I would be soldering that and puttting a piece of glue lined heat shrink tube over it to keep it sealed, just don't keep the iron on the wire for too long as it's so close to the plug it might make the terminal loose. Clickadeeclick |
Thanks, never used a soldering iron. so might be a task for someone else.
| All times are GMT |
