Home > Technical > Suspension Fault Sorted After New Battery Fitted
B9BS X
Hi guys
I was having the suspension light constantly on and suspension button would switch off and bong noise if trying to lower or raise the car, have now replaced brake light switch, have got the new rear led lights so cannot change the rear bulbs, alternator checked out all ok but fault remained, car always raised up to normal height but compressor would then not make any sound so would just shut off with the yellow suspension light which would also sometimes go red and message to drive only 30 mph when on the motorway.
I have now ordered and fitted a new exide battery, fully charged it and did a hard reset before fitting and suspension is working again, the compressor is sounding as it should and car raises as normal Laughing Laughing Laughing
Now I do still have the yellow suspension light come up at start up when pressing the suspension button to raise the car but then dissapears a few seconds later and it also comes back when parking up and trying to lower the car to access level, the light sometimes stays on and car does not want to lower, is there any other reset i need to do as the air compresser is working fine all other times??? Big Cry
Also after fitting the battery i had a low battery message for a split second appear and has never come back so not sure if there is another underlying fault Whistle RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #524898 Sun Apr 30 2017 8:45am
geoffsnook
Have you cleared all the existing faults from memory and then re-read codes after a restart to see what if any codes are present Question
Post #524901 Sun Apr 30 2017 9:14am
B9BS X
sorry forgot to mention did clear the faults and no faults have come back which is strange Big Cry Big Cry Big Cry RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #524902 Sun Apr 30 2017 10:08am
geoffsnook
Does it do you into access mode when you turn car off
Post #524905 Sun Apr 30 2017 11:05am
B9BS X
It does most of the times Whistle RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #524950 Sun Apr 30 2017 11:16pm
