![]() | Home > Maintenance & Modifications > When should i change the Cam Belt? |
Yes it is time or mileage which ever is first |
Moonpig1971 Member Since: 04 Apr 2017 Location: Small Village in Essex Posts: 13 ![]() ![]() ![]() |
It also appears the majority say it should be changed at 7 years rather than 6? Given the mileage i would like to think it will be good until the end of the year? |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
i think it's due at 7 years or 105k miles whichever is 1st Merc C220 estate Sport AMG
Play safe, change it earlier rather than later. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
My manual says change at 7 years or at a stated mileage, which ever comes first. John
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9086 ![]() ![]() ![]() |
Your profile suggests it's a TDV8. If so, there is no cam belt - it's a chain and doesn't get changed. 2012 SDV6 - it's missing a couple of cylinders
Never checked his profile, just from description on original post and no mention of V8. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
I thought the 2010 was the last year they did the tdv8? |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
So does a 2011 3.0 V6 HSE Dynamic have a cambelt or chain? |
Scousefly, That model does have a Cambelt I'm afraid. John
Good spot indeed, thanks for heads up.. Selected wrong drop down by error.. So a TDV6 so i guess a cam belt will be required at the end of the year |
Yes, TDV6 will need the belts changing. 2012 SDV6 - it's missing a couple of cylinders
V8 (petrol and diesel) are chain, V6 (2.7 and 3.0) are belts. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
for the replies guys much appreciated |
