![]() | Home > General (L494) > Coding Hints |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
With my previous drive the Board had an area were members could supply coding information for changing settings on the vehicle. I found this very useful in unlocking features that were installed but were not functioning.
No Have not purchased GAP as there seems to be not much info. I do have the Vag Com lead and software for the SQ5 but will buy the stuff for the RRS when I can see that you can do things other than look up fault codes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 ![]() ![]() |
My understanding was it does more than look up and cancel fault codes. Adjusting the suspension heights for example.
It does but is way behind Ros Tech for instant does not tell which parts have failed like the Vag tools do , does tell you fault code but not much more. This of course may be due to the Land Rover limitations. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
I wonder what the answer is then? I would like that kind of functionality, especially once it comes out of warranty. I bought a flee bay version for my land cruiser, which was a copy of the Toyota Tech Stream software they use in their workshops. That was good and very cheap ($30.00). Be good if there was a similar JLR rip off... |
I don't know but I bet there is a lot of stuff that can be added because the frame work is installed and just needs the know how . I know of a Touareg member that installed Dynamic cruise control, had to add some hardware but the rest was just software adjustments. I think it is wise to own these tools if ony to keep the service techs on the ball. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
The problem with JLR vehicles is that to enable options you need to modify the CCF, or car configuration file, using a software system called SDD (I think that's it).
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Bodsy is also waiting for the MY17 update, as he will be doing a job on mine when it's available. If he hasn't yet got it, I guess no-one has |
rjwojcik Member Since: 05 Oct 2013 Location: Essex Posts: 27 ![]() ![]() |
Any update onany tools available for coding? I too have come from VW/BMW land. |
