Home > General > Key Washing
Pufftmw
Key Washing
Anyone tried this?
Well, I inadvertently left my RRS key in my jeans and my partner machine washed them without checking. Mad panic when I worked out where the key now was - hanging up drying - and a rush outside to check.
Fortunately car unlocked and started up just fine Bow down
One relieved owner...
Post #524192 Sat Apr 22 2017 10:38am
I would recommend you hang the key up by the ring, overnight to allow any water the chance to drain out.
Post #524199 Sat Apr 22 2017 11:24am
Buckster
Put it in a tub of dry uncooked rice! Will take any moisture out Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #524211 Sat Apr 22 2017 3:39pm
Socast
The non keyless entry keys are waterproof.
Post #524216 Sat Apr 22 2017 4:52pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
If there's any risk water might have got in, I'd be opening and giving it a flush with electrical contact/cleaner spray. Water itself doesn't pose too much of a problem (provided you don't try to use it when wet - the dry rice works well) but I'm not sure what effect any soap residue would have for the future, it might speed corrosion which then is your concern. Remove the battery when flushing as those contacts are sure to corrode in future.
But as posted above, hopefully it is waterproof (resistant) so is all dry inside
Dennis 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #524221 Sat Apr 22 2017 5:44pm
