![]() | Home > Faults & Fixes > Brake pedal - spongy/pulsating feel |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
That description sounds as though there is still air in the system. Maybe it needs bleeding again. I'm in the shed, I'll be back in the real world in a minute.
It does sound as if there is still air in the system. |
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 ![]() ![]() |
Thank you Russben and geoffsnook. Should this be something that should have be done as part of changing the brake fluid? RRS 2.7 TDV HSE MY07 |
It would be a natural process to get rid of all the air,that would give you a firm and hard pedal so i would think it has not been completed correctly.So you should ask them to check the system for air or something not completed correctly and re-bleed the brakes as it sounds as if it needs it |
Many thanks! RRS 2.7 TDV HSE MY07 |
So, eventually got the garage to have another look, after they insisted the brake fluid was changed properly and that's not the problem. They now tell me it is oil that has leaked into the brake servo unit and I need to replace that and a modified pipe (as LR had modified the pipe) at a total cost of £600 (parts and labour)!!! RRS 2.7 TDV HSE MY07 |
What car is it there was a tsb for discovery 3 with the same fault amd i would think it would apply to the sport as well it will be worth finding out if yours has been done |
Take a look here to start
Many thanks. Will be giving my local LR dealer a call tomorrow |
Just an update. After being pulled from pillar to post by a couple of Land Rover dealerships I tried. I eventually got it sorted free of charge last week after contacting Land Rover customer service. Took a few months, but at last a result. |
squizzel Member Since: 13 Jun 2013 Location: wednesbury Posts: 193 ![]() ![]() ![]() |
They should have done it right away, we had a recall notice through the post for this on our 55 plate sport. It told us to phone the dealers, they came and collected the car, as it turned out they replaced the pipe, servo and master cylinder, delivered the car back no charge. |
Servicing at a genuine LR dealership, will show up what updates and mods haven't been done, as well as always scanning all codes, clear, then retry after a short test run. It's a shame some indys either don't have the facilities, the correct type of test equipment, or don't have the JLR knowledge, some just can't be bothered. John
no offence but if he was a good indy he would have known about the recall and should really have sent you do a dealer i would have thought |
Cbr60rracer Member Since: 12 Aug 2017 Location: Norwich Posts: 8 ![]() ![]() ![]() |
Hi This happened to me shortly after buying mine. Actually I lost all brakes when driving home from work " scary" because of the oil vapour. I bought a new servo and pipe from Land Rover Norwich for £260 and fitted it within an hour. It's not that difficult to do and will save you a lot of money. Regards |
