![]() | Home > Maintenance & Modifications > My key broken, spare key seems dead? |
Had a similar situation. The second key that came with the car wouldn't start it until I had an Indie code it to the car. Note that you need to give them both keys as need to be done together. Takes a few minutes and cost about £30.
Ptang Member Since: 11 Jan 2008 Location: Bromley, Kent Posts: 95 ![]() ![]() ![]() |
Thanks Paddi - I'll have a chat with my Indie round the corner. |
Completely forgot to add an update. (Only a year late!)
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
Make sure you alternate keys on a regular basis to ensure both remain charged up. 07MY RRS TDV6
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
Is this true for L494 's too? I like to keep one key pristine (sad, I know), so never use it ... |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 ![]() ![]() |
Can someone explain what they mean about charging the keys? I thought they were just simple replaceable batteries. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
The keys have rechargeable batteries in, they charge when they are in the ignition switch. |
So why does the handbook tell you how to change the battery if 'low battery' is warned in the display? (It says it is a CR 2032, the same as the replaceable battery in my last RR). Or are we talking about different key types? (Mine is a smart key). |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
Pre 2010 cars charged when the key was in ignition, the battery is soldered in place in these keys.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Not sure if it will work with the RRS, but over on the BMW forums they reported that using the wireless charger for their toothbrush worked well. Might be worth giving it a shot ?
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Wow - never knew this & explains why my spare wouldn't start the car
