![]() | Home > General > Newbie - Buying my First RRS 4.2 2006 tomorrow - advice |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
There's a buyers guide PDF around, print it off and have a read. Service history is vital. Expect any bill from a garage to include the word 'thousand' when it breaks. Check bodywork carefully, black is prone to scratches in car washes.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Hello Scott. Main thing is to ensure it has a full service history. Brakes and pads are fairly cheap (even so they are Brembo) if you do them yourself.
S666TTC Member Since: 17 Apr 2017 Location: Newcastle upon Tyne Posts: 7 ![]() ![]() |
Great advice, thanks.
____________________________________________________________________________________________________ Cheers D-9, I am prepared for the bills, when they come, all part of the ownership journey i am guessing. Cheap buy in is attractive though, a lot of metal for not much money. |
As above check all electrics work front and rear screens as most fronts will be starting to not demist the whole screen air con is another and any slight lumpiness on tick over and it has to have full service |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Do you have any links to the purchase - us anoraks can tell a lot from a few pics - |
http://www.ebay.co.uk/itm/IMMACULATE-2006-...SwnF9Y7n9O
To me that looks totally untouched from when it left the factory |
http://www.rrsport.co.uk/gallery/albums/us...uide~0.pdf
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
That's non-HST body kit so guess it's standard SC/HSE.
The very first Supercharged did not have kits - they was added to the variant a few months into production - as always great advice from RRSTDV8. Check & check again - even post questions on here if your uncertain before you commit.
Superb advice,I will test to the best of my ability. CAn i just ask if the TV's in the back are supposed to come with a remote control and or wifi headphones for kids? One of the big plusses for us is that the kids will be entertained. My first thoughts are that everything works and works well of course. My second thoughts are on general condition ( i dont want it to be tatty), thirdly, all the nice toys, bells and whistles are great but must work. If there is no remote or headphones for the rear DVD's I assume these are relatively cheap to replace?
The test is if there is a slope in the road surface, if the road slopes to the side, and if it grabs as you change surfaces, go around corners, etc. Just drive it and see if it feels right, or if its all over the place.
The suspension cannot really be adjusted while driving, it will automatically raise itself to normal height from access mode when you pass about 10mph and lower itself to normal height from off-road when you pass about 30mph. The RRS is permanently in 4 wheel drive, you cannot set it to 2 wheel drive, you do have a low-range option for offroading, which gives you the usual 6 gears, but much much lower than high-range. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I personally would avoid one with a sun roof. It's not big enough to be of any real benfit and has a nasty habit of flooding the footwells when the drain tubes block. Granted this can be avoided by cleaning them, but again, based on preference I would avoid them.
