Home > General > RR SPORT FACTORY SPECIFICATION
ADO5TIMES
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi, I understand there is/was a free website where you can obtain the full factory specification of a particular Land Rover vehicle. If this is still available can anyone provide website details. Thanks
Post #523856 Mon Apr 17 2017 5:44pm
Buckster
https://topix.landrover.jlrext.com/topix/v...E.prs72696
You will need to register then you can put your chassis number in and it will give you the spec from the factory Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #523857 Mon Apr 17 2017 5:55pm
ADO5TIMES
Great Thanks
Post #523865 Mon Apr 17 2017 7:05pm
warkman
England 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Buckster wrote:
https://topix.landrover.jlrext.com/topix/vehicle/lookupForm;jsessionid=tgd6fU3oPLvt89AF4LniMEpE.prs72696
Don't you have to pay?
This is another site, put your vin number in...
https://www.vindecoderz.com/ Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #523866 Mon Apr 17 2017 7:22pm
Buckster
Free to register and get the basics, anything more advanced you will need a subscription for Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #523890 Mon Apr 17 2017 10:26pm
TheWojtek
Can anyone decipher my VIN to finally resolve my BT problem? My car does have the steering wheel buttons, however there is no BT module in the space provided (just the TMC thing). So I want to know if it WAS supplied with the factory BT, or not.
The MOST optic fibre cable doesn't seem to be BT-enabled as well, because it's only there for the TMC and there are not other connectors (I assume the loop is terminated at the TMC receiver?) Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #523998 Wed Apr 19 2017 10:20am
do you have red and green buttons on the side of the wheel ?
what do you have on the underside of the arm rest ?
Post #524003 Wed Apr 19 2017 12:06pm
TheWojtek
Yes, the buttons for the phone and voice control are there, the microphone is there and working, the factory highline 6CD/radio displays "no phone fitted" on relevant keypress, there's nothing inside the armrest. Regards etc.,
Wojtek
Post #524004 Wed Apr 19 2017 12:09pm
warkman
I had that on ours (2007 MY)
The screen showed no phone fitted until I went to pair my phone. It needs to "see" the phone to connect
see if this helps
https://topix.landrover.jlrext.com/topix/c...oupId=1654
you have to right click and tell it to open the part of the document in another tab to see the info Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4
Post #524009 Wed Apr 19 2017 1:35pm
well if there isn't anything under the arm rest (like a little connector dock) it just sounds like the steering wheel has been replaced, at some point.
Post #524022 Wed Apr 19 2017 5:50pm
TheWojtek
see if this helps
Thanks, I had a read. I am pretty sure there is nothing to connect to (no module in the boot...) Perhaps it's stuck somewhere elese, but I had three different phones search for the BT and neither did show an available BT speakerphone device.
Also I didn't know the phone dock was an integral part of the factory BT... The steering wheel - I doubt it was changed, the voice control works as intended. Regards etc.,
Wojtek
Post #524054 Thu Apr 20 2017 9:44am
Even without any factory phone, the voice button is fitted and functions
Post #524068 Thu Apr 20 2017 12:03pm
TheWojtek
Aaah OK. But since the phone buttons are there and touching any of them results in the headunit displaying "no phone connected" I assume at least the steering wheel → HU part of the BT system works. So I will need to get ahold a BT module, hook it up temporarily instead of the TMC receiver and hope it works. Shall it connect, I will need an additional MOST optic fibre to add the BT module to the loop and I'm gonna be happy? Regards etc.,
Wojtek
Post #524085 Thu Apr 20 2017 3:05pm
I would have a read over here:
http://www.disco3.co.uk/forum/topic119142.html
Apparently you can just fit the BT module at the front of the car and connect a few wires up.
Post #524101 Thu Apr 20 2017 7:39pm
TheWojtek
Thanks, diving right in. Regards etc.,
Wojtek
Post #524126 Fri Apr 21 2017 8:56am
