Home > General > Bit of technical help needed...new owner .
fog lights are very basic wiring.
If both aren't working, check fuse/link 2 under the bonnet. 30A
This is one of the big fuses.
You need the ignition on for them to work.
And when on you get green and orange lights on in the speedo
So look out for this when pulling the switch, to see if they work briefly before a fuse blows
Post #523302 Tue Apr 11 2017 4:26pm
keithdub1973
Ireland 2008 Range Rover Sport TDV6 SE Java Black
cheers Andy,
spot on mate ! there is a pink 30A fuse link blown...i ordered a couple of spares on ebay and just waiting for them to arrive.
if the fuse link blows straight away , i will check the front fog cables for damage / wear and tear .
btw , im not seeing the green and orange lights on the speedo at all...this might change when i try on eof the repalcment fuse links.
Post #523593 Fri Apr 14 2017 6:16am
the dash lights won't work until the new fuse is fitted.
I would try a careful procedure.
1. Replace fuse.
2, visibly check fuse through the clear window to see if the link is still there.
3. turn ignition on so the dash warning lights are on
4, visibly check fuse through the clear window to see if the link is still there.
5. turn side lights on.
6. While looking at the speedo carefully pull the headlight switch out ONE notch and see if the green light comes on and stays on.
7, see if front fogs are on.
8. While looking at the speedo carefully pull the headlight switch out another notch and see if the orange light comes on too and stays on. Check rear lights are on.
Post #523608 Fri Apr 14 2017 8:42am
keithdub1973
done and dusted Andy.
all went well...cheers mate ! Thumbs Up Thumbs Up
Post #523611 Fri Apr 14 2017 9:43am
keithdub1973
2 second hand OEM horns ordered.. there's one behind the grill on the LHS ... i dont see the other one tho ??
Post #523612 Fri Apr 14 2017 9:48am
