![]() | Home > Technical > lumpy idol |
steve.rrs Member Since: 27 Aug 2014 Location: devon Posts: 90 ![]() ![]() |
mine also has a rough idle. had someone look at it and he said that the valves in the heads may need changing as its been run on lpg
As I have a diesel obviously no experience with the SC but the manual says:
Thanks guys steve was that an indy who said that mine is lpg converted but don't know how much its been used but also has a oil injection system to lube the engine so hopefully no valves to be reground and paddi i have checked as far as i can i have checked the intake side with carb cleaner so my next port for cost i think is the fuel filter thanks for the input guys |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5089 ![]() ![]() ![]() |
Not sure about the earlier S/Cs but in the later 5.0L the fuel filter is a integral part of the fuel pump and is not a serviceable item, it is located inside the fuel tank, so tank would need dropping to gain access to it. Not sure but based on L/R prices wouldn't imagine a genuine pump will be cheap.
yes geoff, there is a mechanic near me who knows his stuff when it comes to land rovers, he connected his kit to the car and said that every cylinder was coming up with a misfire and on a run the car felt a bit underpowered, i also have the oil injection system installed, he said cost would be about £1000 + vat to have both heads repaired.
thanks Steve mine does not feel under powered at all and once not idling it's fine so i assume my heads arnt knackered |
Hi Geoff, i didnt think it was under powered, i tought it was pretty rapid, it was the mechanic when taking it for a test drive, that told me it seemed under powered compared to other sc models he has driven, might be worth getting a code reader on your car to see what codes are coming up
Nothing comes up apart from the P0171 and P0174 |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 873 ![]() ![]() |
On etruely dumb idea for an off road vehicle where getting a load of dirty fuel is a real possibility. I think the Poms need to get into the real bush and learn what 4WD is all about. Some of the design decisions makes me wonder if these cars are built for posers or people that need to go bush ! M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
geoffsnook, did you solve that problem ![]() |
Well not had those codes up in ages after i changed oil and i did see the oil filler was not seated properly but i am waiting for a slot with anew specialist who the garage i use has found who apparently is |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Lumpy idol...
