Home > Technical > Fault Code P2288 Can anyone help
skyranger582
United Kingdom 2006 Range Rover Sport TDV6 HSE Adriatic Blue
Hi can anyone help with Fault Code P2288
Had both EGR Valves changed and Intercooler pipe replaced as it was split.
Still in limp mode and on diagnostics showing Injector pressure too high. Mobile mechanic has told me High pressure pump needs replacing which he cant do as body off job. Is he probably right or could it be something simpler. HELP Big Cry Big Cry Big Cry
Post #523408 Wed Apr 12 2017 11:20am
DrRob
Perhaps get a second opinion from a local LR indy?
http://www.disco3.co.uk/forum/topic146918....dfordshire
Disco3 forum is a good place to look as essentially the same car underneath but lots more cars made and so more forum members * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #523412 Wed Apr 12 2017 11:38am
skyranger582
Thanks Dr Rob
Post #523419 Wed Apr 12 2017 12:06pm
Disco_Mikey
Injector pressure is essentially the fuel rail pressure, controlled by the pressure regulator, which is part of the HPFP
It could be a wiring issue, or faulty fuel pressure sensor, so these should be ruled out first Thumbs Up
Post #523432 Wed Apr 12 2017 2:51pm
skyranger582
Thanks for the info will get them checked
Post #523544 Thu Apr 13 2017 12:29pm
