Home > General (L494) > What should be in the tool Kit |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
well some will get a surprise if they go to change the wheels , jack is Sh!t , and you need a better tyre lever. There aern't many options to call roadside or even find a dealer once outside of cities in Australia. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 11 2017 11:03pm |
I've not pulled that cover yet. Assumed I had the battery but must have a look. I don't keep air compressor in the spare wheel well but carry on trips. The R50 had on board air and air hose, it was far better equipped than the RR in many areas , did however mis a spare which was one reason I went for the RRS. The DPF is an in exhaust filter that needs cleaning or regeneration. In some Fords VW's and other vehicles the regeneration, or declogging of the DPF was done by high temp burning process. My R50 did not have add blue but did have 2 DPF's and needed the fluid for re generation purposes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 11 2017 11:12pm |
I was trying to relate to the BRIEXT mob. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Apr 11 2017 11:15pm |
matsoutback Member Since: 13 Jul 2016 Location: Queensland Posts: 152 |
Full size spare tyre...me too 2017 MY17 SDV6 SE |
Tue Apr 11 2017 11:23pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
I don't think AdBlue is anything to do with the DPF - it is an additive used in a separate catalyst to reduce NOX emissions, not particulates. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Wed Apr 12 2017 9:00am |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 |
majority of people who buy them new would never change the wheel, or even venture out of the big city Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Wed Apr 12 2017 12:34pm |
Correct. The additive is an urea based additive, sprayed into the hot end of the exhaust to reduce noxious gasses to meet requirements of, for example EU6C and Beijing 6 Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
Wed Apr 12 2017 12:36pm |
imf73 Member Since: 15 Mar 2017 Location: kent Posts: 24 |
Hi I have a new 17 plate RRS. I have a spare wheel in the boot with locking wheel nut & Jack but should there be anything in this space in the picture below? I'm sure in my last RRS there was a plastic yellow handle....not sure what it was for, from memory I think it was used if the auto handbrake failed.
Thu Apr 20 2017 11:17am |
donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772 |
You have the same equipment as me, so don't worry as that's all there is. The funnel is or AdBlue, and the yellow tool that you haven't got was for opening a blocked fuel filler neck if you had triggered the miss-fuelling flap. The latest cars have a different miss-fuelling system. |
Thu Apr 20 2017 11:44am |
Nice one thanks |
Thu Apr 20 2017 11:47am |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 458 |
The funnel is for bypassing the active misfuel device ( metal flap over the filler neck) if you need to use a fuel can to get out of trouble. The yellow tool was the reset for the "old" passive mis-fuel device that dropped in to place if you used the wrong nozzle at the pump. I hate to say it but.....RTFM Scrumps Somerset - Where the apples do grow and the cider do flow! 2021 Defender 90 D250 HSE in Tasman with white roof. 24MY D300 AB - Verasine Blue - 😀 19MY SDV6 AB - Byron Blue - Gone 17MY D5 SDV6 HSE - Firenze Red - Gone 16MY SDV6 AB -Aruba Silver - Gone 13.5MY SDV6 "HSE Black" - Baltic Blue - Gone 10MY TDV8 HSE Galway Green - Gone 14MY D4 HSE in Scotia Grey - Gone 05 TD5 D90 CSW in Cairns Blue |
Thu Apr 20 2017 6:08pm |
I believe you are correct . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thu Apr 20 2017 10:33pm |
I might be wrong then, I thought Adblue was there as part of the DPF cleaning cycle instead of the hot burn off...
Fri Apr 21 2017 6:29am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Sorry wrong post In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Feb 15 2019 10:11am |
