Home > Faults & Fixes > dashboard warning message
pinemarten
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Had the RRS nearly a week now. Really enjoy driving it. Took it up up along Loch Shin and Laxford Bridge then back home via Ullapool. Everything worked well apart from one warning on dashboard. "Caution lean when cornering" Whenever we stopped it cancelled out until the next fast corner then on a again. Under Warranty so taking it back to Garage next Monday. Any tips what to look out for when garage carries out repair? They seem to think it might be programming problem. My concern is it might a mechanical problem with the self leveling that could be programmed out but not repaired. Just saying!
Post #523275 Tue Apr 11 2017 12:14pm
TheWojtek
No, your active anti roll bars do not work. Either:
- a leak on the ARB actuator which means new a ARB goes in (pricey!). There is no actual fix for this one, replacement only
- a leak on the hydraulic line (unlikely, though)
- a leak on the valve unit (more or less under the passenger seat, accessible from underside of the vehicle)
I have never seen a programming error with this system, however YMMV. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #523295 Tue Apr 11 2017 4:15pm
