Home > General > Suspension - leaning to the left!
Ianm
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
Ok, so about a week ago I joined the "only normal suspension height" club - which cleared for a few days to be followed by "suspension fault" bottom line is the car is 2" lower on the near side😡 Assuming this is a new compressor job?? Unsure if I should be driving it (stays leaning when being driven)
Any (sensible) ideas? - it's currently a very expensive garden ornament!
Post #522283 Wed Mar 29 2017 8:36pm
DrRob
Get fault codes read first to give you an idea. Use a good local independent specialist near you. Find one by using the search facility on here and input your town or try your county Thumbs Up
A local forum member might offer to do it for you too Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #522286 Wed Mar 29 2017 8:49pm
Paddi
Give Andy a call at Landers Garage:
http://www.landersgarage.co.uk/
Maybe limp carefully up to see them - it is not that far away in Houghton Regis. They know their stuff. Thumbs Up They are open on Saturday morning.
I'm close to you (Harpenden) but unfortunately my IID Tool won't read the codes on your car as it is a different model.
Well - it would but we'd have to pay to add another VIN so not very cost-effective. 2008 MY Java Black TDV8 HSE
Post #522329 Thu Mar 30 2017 12:16pm
TomTerrain
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
FYI, I have exactly the same issue. The lean is very prominent in off-road height! I have IID, and no codes showing! 2006 Java Black HST Supercharged
Post #522940 Wed Apr 05 2017 12:59pm
stornoway10
United Kingdom 2013 Range Rover Sport SDV6 HSE Orkney Grey
Mine did that
Ride height sensors want recalibration or faulty parts replacing
Reecy
Post #523103 Fri Apr 07 2017 8:50pm
TomTerrain
Ride height already recalibrated. My air bags are original and looking pretty worn, so might change them out 2006 Java Black HST Supercharged
Post #523106 Fri Apr 07 2017 9:18pm
Ianm
New compresser fitted @ independent garage & alls well, £1000 all but a beer
Post #523118 Sat Apr 08 2017 7:51am
£1000 to supply and fit a compressor? Sounds a bit steep. 2012 SDV6 - it's missing a couple of cylinders
Post #523128 Sat Apr 08 2017 1:55pm
GodivaNige
Was the thing thinking the same, my local Indy (venture 4x4) charged £685 to change a Hitchi to an AMK
Post #523131 Sat Apr 08 2017 3:23pm
grey17
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi mate.
I had exactly the same issue on my TDV8 when I first bought it a few months back. There were two issues with it listed below.
1. Two of the suspension legs had worn shocks and didn't allow it proper damping. If you push hard on the front bumper to bounce it, it should bounce evenly. Mine didn't and bounced from side to side indicating a worn shock absorber.
2. Go to you nearest Land Rover dealer and ask them to recalibrate the suspension height for you.
I wasted a lot of time going to an independent garage who told me there was a fault with the height sensors. All four were replaced and still the same fault existed.
They told me that they had recalibrated the height and that it was impossible to adjust any further.
I took it to Land Rover (Chipperfield) who were nothing short of amazing and extremely helpful.
I spoke to the chief mechanic there who explained that the machines most indy garages have cannot access in enough detail what the main dealer computer can do.
I let them have the car for two hours and it came back dead level and has been so ever since. They also updated all the software at the same time so I was very happy.
It cost about £300-ish from memory and well worth every penny.
Hope that helps.
Post #523232 Mon Apr 10 2017 4:14pm
