| RRSPORT.CO.UK | ||
|  | Home > Technical > Traction Control activating on corners |
| garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071    | It is not traction control that is activating but stability control is kicking in as the systems are detecting some yaw when cornering.
|  Fri Apr 07 2017 10:52am |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Ahh yeah, that's what I meant, the dsc.
|  Fri Apr 07 2017 2:28pm |
| SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27    | Your steering wheel angle sensor might need recalibration. | ||
|  Tue Apr 11 2017 5:01pm |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Already done  | ||
|  Tue Apr 11 2017 5:13pm |
| SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27    | Pleased  to hear you got it sorted.   | ||
|  Tue Apr 11 2017 5:44pm |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Hahaha, I meant the steering wheel angle sensor, not the actual issue   | ||
|  Tue Apr 11 2017 5:58pm |
| SAS32 Member Since: 05 Feb 2017 Location: UK Posts: 27    | I'll retract that   | ||
|  Tue Apr 11 2017 7:23pm |
| Bowesman Member Since: 18 Oct 2016 Location: Leeds Posts: 14      | Hi TomTerrain,
|  Fri Jul 14 2017 8:11pm |
| Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003      | Had the same issue on my D3. Found the rear upper sus bushes were shot on one side which is why the DSC was only kicking on when cornering in one direction only. Replaced bush problem sorted .. 2008 G4 RRSport TDV8 current
|  Fri Jul 14 2017 9:48pm |
| Bowesman Member Since: 18 Oct 2016 Location: Leeds Posts: 14      | thanks Camelrock, will check that out tomorrow. Taken it to a local indy garage but asked them to check the front again due to rough ride, didn't think it could be rear | ||
|  Fri Jul 14 2017 10:37pm |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Not yet:(. I've been sorting out a new vehicle so not had a chance! I'll check the rear, but I have a knocking from the front, so I'm sure it must be there somewhere! 2006 Java Black HST Supercharged | ||
|  Sun Jul 16 2017 5:55pm |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Bowesman, have you had any luck?
|  Fri Aug 04 2017 5:55am |
|  Mon Aug 07 2017 9:02pm |
| TomTerrain Member Since: 07 Sep 2015 Location: Wirral Posts: 93      | Does it squeak when you're going over bumps? And knock when you turn? It felt like there was something loose in the steering!
|  Mon Aug 07 2017 9:11pm |
| Posting Rules
 . Thanks for the input though
