Home > Technical > Oil pump
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Oil pump
I'm about to start pulling my tdv6 apart to do timing belts so will do oil pump to, even though it looks a mission! .
Lots of pumps on eBay ranging between 90 quid and about 240 . Any one got thoughts on which or which not to get or would you recommend Land Rover ?
Thanks
Nick
Post #522357 Thu Mar 30 2017 7:34pm
go citroen
OEM and cheaper than LR
Post #522358 Thu Mar 30 2017 7:57pm
m3nutter
Thumbs Up cheers Andy
Post #522374 Thu Mar 30 2017 9:11pm
m3nutter
It's all apart and ready to be built up , problem is I've lost one of those green seals from the top of the old pump and I'm worried it's gone in the sump Sad , I've looked everywhere Sad
Post #522781 Mon Apr 03 2017 8:13pm
SRE
Spain
Do a search on the Disco 3/4 Forum, loads of info ref the oil pump and pump seals etc Thumbs Up Disco Mikey undertook quite a bit of research into the different pumps and seals Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #522840 Tue Apr 04 2017 10:57am
m3nutter
ok cheers mate Thumbs Up
Post #522841 Tue Apr 04 2017 11:24am
SRE
Spain
Just for starters Thumbs Up
http://www.disco3.co.uk/forum/topic53674.html?highlight=oil+pump
Plus
http://www.disco3.co.uk/forum/topic134719....+oil+pumps In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #522872 Tue Apr 04 2017 4:14pm
m3nutter
just finished, taken me about two and a half days in all, done oil, filter, oil pump, timing belts. worst bit was definitely the pump and getting the starter out of the way to get the lock in.
What i would say is i didn't remove the starter. i moved the fuel cooler, unbolted the starter then pulled it towards the front of the car as far as it will go which is just far enough to get the bendix out of the bell housing then pull it down and leave it.
you can then unbolt the fuel pipe clip, flirt the bung out and put the tool in. all by feel as you can't see it.
make sure you bolt the tool through the top starter bolt hole (a 13mm bolt) to hold it in place.
crank bolt came undone with a big breaker bar and then the new bolt did back up but i have to admit i was worried the lock would hold it.
after that i marked the crank pulley to the new pump.
the tool was stuck and took some riggling to get out.
Post #523038 Thu Apr 06 2017 7:37pm
