![]() | Home > General > New to RR Sport and first issue. |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
I wouldn't have thought its the valve block for the ace system, if it where screeching you would no doubt get an error message on the dash (due to the valves not responding correctly).
rainifa Member Since: 09 Mar 2017 Location: Plymouth Posts: 8 ![]() |
Thanks for your quick reply.
Other than the gearbox, I can't really think of anything that is effected by engine rpm's (in that area), the valve block would be effected by engine speed, but as I said I can't see it causing the noise. |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Could it be noise transference from the engine bay? With under trays in place, it may be coming from engine bay, but sounds like its under the drivers seat? Just bought a RRS 06 MY HSE TDV6 136,000 miles, to be a second car to my bland, boring Mitsubishi Outlander 68 plate 2.0 petrol 4 |
It could be and a couple of posts on various forums has pointed to power streering or alternator, so I will investigate further. |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2022 ![]() ![]() |
Welcome to the fold |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
Look at the parking brake and rear callipers. I to thought my screeching noise as in the front but turned out to partially seized EPB, sticking rear passenger calliper and sticking rear pad on drivers side |
I think I will try and isolate noise and report back. Thanks all so far. Anyone with knowledge of a good local Indy? |
http://www.disco4.com/forum/topic90350.html?highlight=Devon
