![]() | Home > General > Front A R B bushes |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
I just purchased the special land rover tools from Dan at Duckworths
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Many thanks rob , let me know how you get on ( difficulty rating ? ) . Those tools are quite expensive but I guess if it's a case of having to replace the front bushing every couple of years as I've read they may be a good investment ! Good luck |
Err dont think you read my post properly |
Your quite right rob I didn't read it properly , it's a pity your so far away I would gladly pay you to do mine ! I've emailed 2 local Indys to quote for the work and neither have bothered to reply after 3 attempts , think I will have to use the good old fashion telephone 😄 . Did you use landrover bushes or the powerflex ones I've read about on here ? And did you get the new bolts from a Land Rover dealer ? Sorry for all the questions ! Many thanks |
New LR bushes and the new design clamp came with new ARB bar
Hi rob , just had the sport in for new bushes but they have found that the active bar is leaking over one side so they suggest new anti roll bar with all that goes with it for £1550 , just wondered how you found your car sounded ( knocks and thumps ) after you'd had the newARB . Major improvement ?? Cheers |
Yes was a dramatic improvement but to be honest that may be down to the new bushes and slightly re designed clamps rather than the ARB bar as never really lost that much fluid
