Home > General > Odd Occurence
Hutch41
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Odd Occurence
Yesterday afternoon I'd just started a journey when suddenly the engine started noisily racing and the rev counter leapt up to twice it's normal reading.
I stopped....turned off....gave it a minute or two then started up again and all was well.
Never come across this before......can anyone diagnose the possible cause ?
Post #522396 Fri Mar 31 2017 9:22am
Pufftmw
I had this once on a 2.4 D5 Volvo - accelerated hard and then when I came to change gear, revs just went mad.
It was to do with some sort of chain combustion but it was because I'd burnt out the pistons on the engine due to some Censored mechanic having put a new engine in but not attached one of the sensors correctly (in fact at all) so it was letting too much air in and running too hot.
Its probably not related to your issue but definitely get the fault codes read, its not normal behaviour.
Post #522408 Fri Mar 31 2017 10:42am
Mani
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
Hi pal it could also be a pos transmission fault Thumbs Up
Post #522410 Fri Mar 31 2017 10:59am
Hutch41
Thanks to both of you
I'll get the fault codes read as you suggest.
Post #522460 Fri Mar 31 2017 8:04pm
drdelrrs
Is it at a gear up-change point? Low transmission fluid or torque convertor issue?
Post #522550 Sat Apr 01 2017 5:49pm
Hutch41
Solved
I must confess that the problem was all my fault.
It happened twice more and then my son pointed out that I was clicking the "gear down paddle" on the side of the steering wheel by accident whilst steering.
(Clumsy old fool....maybe should have stuck with a simpler car)
Post #523071 Fri Apr 07 2017 10:03am
JOCK55
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
If it bothers you, you can turn the paddles off using the menu available from the steering wheel. Well, you can on mine!
Old Jock 2018 (MY19) Jaguar F-Pace R-Sport 300PS Petrol in Caesium Blue with many bells and whistles.
2015 RRS HSE SDV6 Firenze Red with Santorini Panoramic Glass Roof, gone but not forgotten.
Post #523130 Sat Apr 08 2017 3:20pm
Hutch41
Thank you Jock...I'll check if that facility is available on my car this morning.
Post #523258 Tue Apr 11 2017 9:00am
Hutch41
No...the option to disable them doesn't appear in the little window so we're stuck with it.
(Must say I don't quite see the point of them and they clutter up the steering wheel)
Post #523260 Tue Apr 11 2017 9:27am
Russben
It's because the 2012 model has the silly round gear selector and not a proper gear lever so there has to be some way of manually selecting gears when off road. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #523331 Tue Apr 11 2017 8:29pm
Hutch41
Oh I see....I did wonder what the reason was.
I love that circular "disappearing" selector though...(always did like gadgets)....and as I never go off road it doesn't affect me.
Post #524547 Wed Apr 26 2017 5:15pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Ha ha, the silly round gear selector is what appealed to me over the stick - sticks are for manuals...!
Maybe it's the same with newer models, but Jaguar have it sorted as my XF (with silly round selector) could have paddles disabled when in Drive, with just a quick change to Sport and have use of paddles. Makes sense to me as D can be for lazy driving, then S for offroad, manual control, or whatever. Accidentally knocking the paddles when in D really frustrates me. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #524549 Wed Apr 26 2017 5:40pm
Russben
It begs the question if Jaguar can isolate the paddles when in drive, then why can't the same parent company using the same basic equipment do the same in a Range Rover?
Given a choice I'd much rather a manual gearbox, but JLR took that option away from Range Rovers and their bigger jaguars.
At least the RRS2 has a stick, and I can look forward to that when I change cars.
Everyone has their own preference. Thumbs Up I'm in the shed, I'll be back in the real world in a minute.
Post #524550 Wed Apr 26 2017 5:59pm
Johnski
You, should be able to turn them off, I believe, (or a JLR dealership) using a GAP Diagnostic IID BT tool if you have one.
A very good tool and code reader which allows you to adjust so much. Thumbs Up John
Post #524600 Thu Apr 27 2017 1:07am
