![]() | Home > General > Internal plastic and metal look trim scratch removal |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 208 ![]() ![]() ![]() |
Mine looks the same and I don't mind the look, maybe the finest steel wool available? 2018 Telsa MS
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
If it's not metal and just painted plastics then you can use the same polish you would on paint. For such an intricate area I would use a dremmel with buffing wheels, and if you have a selection of polishes to use, go with least aggressive first then work you way to most aggressive or until you achieve the correction your after. |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Thanks folks,
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
Use a silicon spray or if you have some wd40 handy spray a bit of that on. |
I have both of those, but I can't think how they'd hide scratches as I'd imagine they'd maybe emphasise them? I can give them a try though. It's just little scratches which if on bodywork paint would just disappear with a compounding, but initially I wasn't sure on the metal due to the satin type finish. I was thinking if I used a metal polish then it may polish it to a shine, but I also was wondering if it was plastic or metal coated with a lacquer of some sort so it would polish out - this is now what I think it is after having checked it with the paint thickness gauge, but it is very thin, maybe too thin to compound. But, as the scratches are very light then I maybe should look for a filling polish which might fill the scratches rather than remove a layer of lacquer with the possibility of going through and shining the satin look. My wife says she can't even see any scratches, but I'm sure her optician uses jam jar bottoms in her glasses.... 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
