![]() | Home > Maintenance & Modifications > Anyone had the chrome edge of their side steps ping? |
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1559 ![]() ![]() ![]() |
I remember seeing some comments on this forum about this. Think the rivets give up. Some have re-riveted IIRC Robin
Have a look here http://www.rrsport.co.uk/forum/topic46485.html?highlight=rivet Robin
Thanks both.
I guess so. Sorry don't know for certain. However if you can use a bolt but still keep it looking ok then that would have my vote. Robin
Think I might go for some replacements, as I can imagine the other side will also be going.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
Get a cable tie on the end for now. |
Great idea!
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Just had the same thing on mine, the aluminium rivets corrode with age. I removed the complete sidestep to repair it and drilled out all the rivets. I used some 1/2" self tappers and large head washers to re- fasten the strip, you will need to clamp it in place as it does spring out when the rivets are drilled out. Much easier taking the whole step off to repair as you can turn it upside down to work on it. 2010 RRS, TDV8
So worried if I removed mine they would fall apart with rust |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
happend to me a little while ago, i just removed the step and riveted it back in place |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Yep, also happened to both mine, I removed them cleaned up as best I could the drilled outbthe old rivet and re riveted it back on. Should last until I sell up.lol |
Lol, you have to love eBay.
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
Thanks for the info everyone, one of mine has started to come away. |
