Home > In Car Electronics > Android 6.0 8.8 inch Head Unit Install
Page 1 of 4 1234>
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
So since September I’ve done very little on this project as it has been working quite well and I liked the optics it offered.
The changes I have done though are basically instead of using an old touch screen surround cut back and mounting it to the tablet screen I’ve cut slots into a new surround and now slide the tablet through this gap. I feel this gives a much better appearance. This is further supported by a gutted touch screen cradle plus angle brackets and double sided foam tape. All-in-all a very sturdy construction. The pictures below are interim and the rough edges etc. have now been finished of to an altogether better finish.
I also played around with the home screen layout and revised some of the Tasker App profiles to manage automated processes including launching Sygic navigation on power connection and closing on power loss. Also screen brightness etc were automated. Here's a quick pick of the new home screen.
Unfortunately, a mate of mine was looking for an Android build for his Beemer and whilst we were discussing options I started thinking and found this. It’s an 8.8 inch Android 6.0 head unit running the same resolution as the current 8.8 and 10.25 inch Beemer OEM units Very Happy
Having talked to the supplier and Gary at InCarTec I’ve now ordered a similar unit and am waiting to get it in my hands to have a play. Basically it will replace the OEM stereo, in the same location. I’m going to use a spare head unit fascia as the surround and hopefully fit the stereo flush to this. Based on my measurements it should fit snugly both in height and width. Very Happy Which is why I’m going ahead as I personally do not like the ‘empty space’ around a double DIN build.
I will then retain the MediaPad in the touch screen location and decide how to combine the two, using the 3.5mm headphone out of the MediaPad. However, I think I’ll use the Mediapad for an “on screen” clock and other info (weather, calendar, etc.) in default ‘mode’ and actively use it for movies etc. if required.
Below are a few mock ups of what it should look like once completed?
One concern Gary did have was the amplification of the Android head unit. If this turns out to be poor as he suspects then I’ll consider using separate amps to power everything…
So what you think ladies, gents??? Crazy, good or just plain stupid?? Very Happy
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #522121 Tue Mar 28 2017 8:45am
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
personally i think it's quite impressive, the vision and the know how plus the patience to carry it out. 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #522123 Tue Mar 28 2017 9:10am
Guyzer73
Thanks Pakolainen Thumbs Up
Well a small update. I've received the head unit and it powers up which is far as I will get until it's installed.
Here are a couple of photos:
One thing you may note is that the surround isn't plastic but metal... Doh! That's going to complicate things a little.
I then hacked apart a spare stereo fascia, hacked being the operative word, to see how the two meet up compared to my calculations and bearing in mind the new issue with the metal fascia.
Again some photos:
All-in-all, I am actually quite happy, and quietly confident that it'll work. So now I'm going to give the fascia and the stereo to my trusty garage and get them to mate them up, top and tail the metal fascia to fit and manufacture the brackets that will be mounted to the stereo chassis and mount onto the OEM mounting points.
Once this is done I'm going to initially install the stereo using the InCarTec kit and get it all functioning. Then and only then will I return the stereo to the garage for them to finalise the fitting and the prepare and paint the fascia.
Then it is the home straight with installing the new spoiler mounted reversing camera (from InCarTec), wiring it up to the new stereo and then re-configuring the tablet which is already installed. The end result should be a 100% Android In Car system running Android 6.0 all round and with full customisation and phone integration Very Happy
But that is some way off and there is oh so much that can go wrong in between....
So fire away ladies and gents, let me know your thoughts Thumbs Up
Post #522839 Tue Apr 04 2017 10:41am
And the award for perseverance goes to........
Have said it before, but very impressed with this, moreso as it is something that I couldn't even consider, let alone implement.
Well done Sir Thumbs Up ON THE WAY: BMW F21 M140i
Post #522844 Tue Apr 04 2017 11:52am
Guyzer73
Thanks Beancounter_74 Thumbs Up and I'm continuing.
Well due to heat and lack of spare time I've passed the Project onto my go to guys at the garage. They've had a play and as of today this is where we stand:
The fit looks spot on and it should integrate very well into the existing dash. Finally a modern main display supported by a secondary tablet in the OEM touch screen location Very Happy
By the end of the week the brackets will be done, the filling/ sanding completed and the majority of the external cabling done. This will allow me to have a play before my holidays, and at least power it up and may be even do some configuration.
However, because of the timing, and Ramadan and my holidays little progress will be made until July Sad , but then a 2-3 day hit should get this and the spoiler mounted camera working Smile After that it's configuration time and deciding whether to install separate amps for all the speakers....
So what you think?
Post #525555 Mon May 08 2017 8:54am
Guyzer73
Now with the protective card taken off, filling/ sanding underway Very Happy
Personally think it looks Censored good, hopefully with the Kenwood amps and a decent interface this build should really hit home.
Hopefully tomorrow I'll collect the head unit with the brackets installed and have a proper trial fit and power up over the weekend latest. Initially I'll run it with the head unit amplification but expect to install the external amps asap.
Let me know your thoughts.
Post #525695 Tue May 09 2017 11:52am
TheWojtek
This is insane.
If this thing can do FM/Spotify/satnav/iPod and steering wheel controls, I will bring my car over to you with a bucketful of cash and ask for a build of this kind. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #525706 Tue May 09 2017 12:54pm
Guyzer73
Yes it can Very Happy , or at should be able to. But it's a looong drive from Poland to Muscat Wink
Check it out here. Lots of others to chose from but happened to choose this one as it looked the best fit.
However, if it all works your local car audio experts should be able to do this no problem Thumbs Up
Post #525707 Tue May 09 2017 1:03pm
Guyzer73
And the great Range Rover God of the mud said, let there be POWER!!
and there was:
It's working Very Happy
Loads to do but it's proof of concept, and I know you guys say no photo, didn't happen Wink so there you go.
Whats to do? loads, not in any pareticular order though:
1. Get speakers working initially with InCarTecs speaker bypass then with amps.
2. Pair bluetooth and WiFi - DONE
3. Get steering wheel controls to work
4. Change boot animation from Toyota to Range Rover/ Land Rover - ONGOING
5. Finish surround in piano black
6. Make cabling nice
7. Strip down and relocate OEM stereo - DONE
8. Download apps, map data etc - ONGOING
9. Attach USB drive with music and movies as the internal hard drive is limited to 16Gb
10. Install new rear spoiler mounted reversing camera and hook it up
11. Position external mic in OEM location.
12. Position external GPS receiver in OEM position.
13. Trial Nova launcher interface and also Android Auto & Automate beta
Well that's it for now.
Let me know your thoughts Very Happy
Guy
Edited: For updates plus additional items on list. 2006 RRS S/C CONSTANTLY under modification...
Post #525835 Wed May 10 2017 7:33pm
TheWojtek
Speechless.
If there was a possibility to route the stock 4x4 info screen to the big one in order to replace the small stock touchscreen with the basic Disco3 empty box... that would be the king of all systems for a RRS. Regards etc.,
Wojtek
Post #525841 Wed May 10 2017 8:58pm
Guyzer73
@ TheWojtek, I don't think that would be possible, at least not directly. However, if you can think of a way please let me know Smile
Apart from that I'm liking having two customisable screens in the car, I should be able to get an awesome setup sorted out. The only gripe I have is that the top screen is still unreadable in direct sunlight, something that happens a lot here.
Ultimately thinking of designing some kind of 'visor' to be added to the dash top to give some 'shade' to the screen.
Post #525861 Thu May 11 2017 9:02am
Bow down Bow down Shocked Cool
That is superb Guyzer, hats off to you, Thumbs Up
Is this just a one off prototype for your own personal amusement, or have you ambitions to make something that is marketable? I'm sure there would be people who would like to spruce up the inside of their first generation RRS's.
Good luck with the next items on the list Thumbs Up ON THE WAY: BMW F21 M140i
Post #525865 Thu May 11 2017 9:28am
Guyzer73
Cheers Beancounter_74,
It's for my own amusement. Whilst I can see the market for it the cost is significant when you consider the head unit, InCarTec's various harnesses and then in all likelihood two further amplifiers, associated cabling, spoiler mounted rear view camera etc. Not to mention my location isn't great for shipping things to the UK/Europe...
However, once completed and working properly I upload a guide of sorts on how others can replicate this build.
I'm going to need the luck, as the say 80% of the work for 20% of the time/ cost, the final 20% takes 80% of the time /cost. In this case time as it's all the fiddly wiring and configuration that needs to be done. Currently driving around with no audio whatsoever, which I hope to rectify tonight.
Post #525867 Thu May 11 2017 10:01am
No audio, that would do my head in, I think I'd have gaffer taped a Bluetooth speaker to the dash by now to run from my phone Wink ON THE WAY: BMW F21 M140i
Post #525868 Thu May 11 2017 10:30am
Guyzer73
Rolling with laughter something similar had already crossed my mind...
Let's just say if I can't get the audio wired up tonight I think I'll be 'installing' my Bose Soundlink in the car until it's working... Whistle
Post #525869 Thu May 11 2017 10:38am
Page 1 of 4 1234>
