![]() | Home > Technical > Cam belt |
Better safe than sorry i say get them spanners out |
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
I reckon you're right.
it was not the bracket it was a bad batch of oil pumps where the casting was floored and failed so while you are doing the belt its worth doing the pump at the same time |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5081 ![]() ![]() ![]() |
Yeah get your front belt and oil pump replaced.
How much should I be paying for a kit with idlers ? |
Look on eBay. Used to do a kit with aux belt too
Ok mate thanks,
Dont know. The Citroen pumps are better priced. |
The crankshaft pulley is not on a key way and it needs to locked via the flywheel locking tool., Advanced Factors have all you need including the oil pump.
Ok thanks , so it's just a taper , I'm just thinking once it's off any timing reference is lost so you have to use flywheel ?
