Home > In Car Electronics > How to avoid a flat battery
Eaters
Hmmm. Just a few words to help any others as stupid as me. Wanted to pump up the tyres on my bike and being lazy, decided to use the electric pump I carry in the RRS. Used the power socket in the boot and it worked just fine once I had turned on the ignition - just to the first position you understand so that there was power in the rear socket.
A few hours later, I couldn't find my car keys. Then remembered they were still in the car. Ok. Retrieved them, went to lock it and - nothing happened. Battery was as flat as a pancake. Only one year old and just 3 volts showing.
Now with any normal car you just recharge and that's it. But this is an RRS so PANIC. So I put it on charge. Do I disconnect the battery like the instructions say or leave everything connected? I decided that the minimum disruption was best and so just connected up the charger.
Tried it after 2 hours. Not a sausage. Tried again after 5 hours and miracle of miracles, it started.
So then I started to look for what damage had been done. All the dashboard lights looked normal! Thumbs Up Clock had reset but I sorted that. There were no radio stations but then they just started retuning themselves. Took it for a 40 minute run and all seems ok. Turned it off, and the a bit later took it out for another run. Still ok!!! It's on trickle charge as I write this.
Touch wood, no issues.
The moral of this story is that there are an awful lot of electrical stuff you switch on when you turn the key so be careful how long you leave it on. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #521911 Sat Mar 25 2017 7:48pm
riverblanche
every day is a school day, as long as you learn from it Thumbs Up
you don't mention How you connected the charger Question but best not to connect directly to the battery terminal posts
trickle charge via a tow socket is good
Post #521912 Sat Mar 25 2017 8:24pm
DrRob
Ok to connect the positive direct but negative should be clamped to an earth and not the negative battery post....that's my understanding.
Please correct me if I'm wrong..... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #521917 Sat Mar 25 2017 11:20pm
Eaters
I'm sure I read that somewhere but by o-level physics says " what's the difference?" So I just connected to the terminals Embarassed Embarassed
Fingers crossed tomorrow when I try to start it! Robin
Gone:
MGZTT 190 2.5
Post #521918 Sat Mar 25 2017 11:44pm
People just worry about things sparking near battery vapors and causing an explosion
hopefully the battery vent pipe is connected anyway
Post #521920 Sat Mar 25 2017 11:47pm
garrycol
Australia
Yep no different to any other car - there is nothing mystical about the RRS if you leave the ignition on in any position and charging the battery is exactly the same as any other car. It is easier to put the negative lead of the charger on the body post rather than try to get at the -ive on the battery but all else is the same.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #521921 Sun Mar 26 2017 2:36am
Eaters
Riverblanche - on a slight aside - I have two tow sockets fitted (and presumably wired) but have never towed. I believe one is for lighting and the other is for power to say a caravan. Which I would use to trickle charge? And is there a note somewhere about wiring up a plug for this? Robin
Gone:
MGZTT 190 2.5
Post #521923 Sun Mar 26 2017 8:20am
Buckster
If you go in the forum shop you can purchase a plug for use with tow electrics and a trickle charge 👍 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #521924 Sun Mar 26 2017 8:33am
Eaters
Cheers Buckster Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #521926 Sun Mar 26 2017 8:41am
Buckster
Not sure what charger you have but i use a CTEK via a 13pin on the tow electrics Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #521927 Sun Mar 26 2017 8:46am
White plug for power.
Pin 3 earth
Pin 4 +
The plug in the shop is suitable if you have a CTEK charger.
If you have a normal charger you can get a plug off ebay (a 12S) for a couple of quid.
Post #521933 Sun Mar 26 2017 10:59am
riverblanche
only get on every few days Rolling Eyes
ISTR don't connect straight to the battery posts as it can upset the BCM, not sure if the 2006 has it but later cars def do Thumbs Up
Eaters, yes its the live supply to the caravan, I have wired a spare S plug as I use the motorbikes optimate Thumbs Up
From the shop already done great for the Ctek
Post #522086 Mon Mar 27 2017 5:55pm
Eaters
Thanks for the thoughts and advice all.
Post script to my story, everything is back to normal and all working just fine. Don't know what the panic was for.... Whistle Whistle Robin
Gone:
MGZTT 190 2.5
Post #522116 Mon Mar 27 2017 11:09pm
