![]() | Home > In Car Electronics > Head unit issues |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5117 ![]() ![]() ![]() |
Out if interest, what parts have you swapped. |
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
I have put the working CD changer into my unit. I still have my circuit board etc. from my old unit. It almost seems like my circuit board doesn't like the cd changer and the other circuit board doesn't like producing sound.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Can you not change the volume on the replacement unit using the steering wheel controls ? |
No it seems to have gone into phone mode. I get phone mode on the screen and the sound now comes in and out |
Might be worth buying a known working one, as the replacement you bought sounds to have more problems than just no sound. |
May just stick with mine and do away with the CD player. The annoying thing is that the cd changer works in the one I purchased but just not in my headunit and I cannot for the life of me understand how my headunit shows the same issue with 2 different cd changers. Unless the circuit board is somehow broken but only in relation to the cd changer. |
I've not seen CD1 on the display before.
Mine has the circles but also cd1 or cd2 in the top left corner.
Just been using mine.
Might be worth looking at the phone cradle in the centre cubby box. there may be a short or a pinched wire. I've removed the cradle from mine (being as I dont have a nokia 3310 |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Think the fact that the sat nav screen stays on land rover logo points to an issue with the fibre optics too and if getting problems with phone I would try unplugging bluetooth unit in rear quarter panel to eliminate that from the system. as soon as you unplug it the sat nav scrren would have stayed on the LR logo unless you use a loop like below but at least you will know if thats causing your problem as if issue with fibre optic loop you will have no sound
