Home > General > Diff oil leak
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Diff oil leak
Does anybody no if the breather pipe on top of front diff has a one way valve in it
Oil leaking from back of front diff took plastic pipe off top of diff blocked cleared it with airline when connected back to breather pipe on diff blew down it blocked if it doesn't have a one way valve any suggestions on how to unblock it thanks in advance 2,7 rrs 56,plate
Post #521571 Tue Mar 21 2017 8:41pm
There is a small valve cap at the top of the breather pipe next to the radiator on the NS. Cut it off and replace with the revised larger version.
I would worry that if it's leaking then the seal is already shot... 2012 SDV6 - it's missing a couple of cylinders
Post #521572 Tue Mar 21 2017 8:53pm
Bullnogger
Thanks for reply mate
I have already swapped that i don't think there will be a one way valve in tube at top of diff I think that's where it's blocked and caused oil leak as it can't breath but how do I unblock it
There's nothing to undo to take pipe off diff it's just a curved small pipe with a small rubber tube that connects to breather pipe from engine bay
Post #521573 Tue Mar 21 2017 9:15pm
The pipe is removable because it is removed if the diff is dropped. Hopefully one of the mechanics will be along soon to give more advice. 2012 SDV6 - it's missing a couple of cylinders
Post #521584 Tue Mar 21 2017 11:51pm
Bullnogger
I hope so mate where metal breather pipe that comes off diff looks round no nut attached to unscrew it off
Will hopefully be able to get it off going try air line on it at weekend first to see if I can clear blockage
Post #521588 Wed Mar 22 2017 7:26am
