![]() | Home > Technical > Air Suspension - driving me bonkers |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4823 ![]() ![]() ![]() |
small corrections in height are normal after shutting the door.
Wallaby Member Since: 17 Mar 2017 Location: Lincolnshire Posts: 3 ![]() ![]() ![]() |
Thanks Andy,
m3nutter Member Since: 08 Jul 2016 Location: Fairoak, Eastleigh Posts: 145 ![]() ![]() ![]() |
On the carpet I took some garden stuff to the tip and something leaked in the boot. Took me weeks to get rid of the smell. Finished up pulling al, the tool tray, false floor and cover out of it and leaving it all day with it open to air it |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1062 ![]() ![]() |
When you jacked the car did you jack it in the correct jack position on the chassis or jack it under the the nearby air compressor - in the heat of the moment many people have jacked the car on the compressor causing issues rather than under the chassis. The plastic lower case of the compressor has a hole in it like the chassis has.
Thanks Garry,
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2009 ![]() ![]() |
There was a post somewhere on Disco3 forum about different sized tyres on same axle causing issues...
The car defaults to "normal mode" |
richardsimkiss Member Since: 13 Feb 2017 Location: Warwickshire Posts: 9 ![]() ![]() ![]() |
I'd follow up on the 'different sized tyres' comment... having recently read a thread which touched on funny gearbox behaviour and the gearbox not shifting when it was supposed to, it turned out to be that the tyres, despite being the same specified size, were from different manufacturers and turned out to be about an inch different in diameter IIRC! Basically the car thought it was cornering so applied its usual 'gearchange whilst conrnering' rules.
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 194 ![]() ![]() ![]() |
Back in 2006 some milk was spilled in my car back in Canada. I still have the car when I travel back and yes to this day I can still smell milk when it's hot inside!! 2018 Telsa MS
http://www.rrsport.co.uk/forum/topic35871.html Visitor from fullfatrr.com
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
Hi Wallaby, I had a leak sounds similar to yours check out a guy called Gruodiz on this site he sold me a great piece of kit and fixed the problem at a fraction of the cost |
