![]() | Home > Technical > Propshaft question |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9087 ![]() ![]() ![]() |
A judder under load up hill is often a sign that the torque converter lock up clutch has seen better days. What variety of RRS do you have, how old and how many miles has it done? 2012 SDV6 - it's missing a couple of cylinders
Gazboxer Member Since: 21 Jan 2015 Location: Chorley Posts: 6 ![]() ![]() |
Hi Its a td6 2.7 2006 with 133k miles on it |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
It's easy the check the centre bearing, to be sure. A complete replacement rear prop is about £295, so not too bad. It's an easy DIY fit too. |
