![]() | Home > Technical > Key Fob not opening central locking and immobilising engine |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Are you sure that the key is sending a signal ? |
| Jen Member Since: 17 Mar 2017 Location: Isleworth Posts: 4
Well, the red light flashes when the buttons are pressed and the batteries have been changed, so as far as I can tell its working. I only have the one key. |
Sound's like you may need a new key, or at least need it reprogrammed.
OK, thank you |
| donny dog Member Since: 23 Nov 2016 Location: yorkshire Posts: 772
It may not be connected, so it may not help, but I had a similar problem several times on my wife's Evoque. I identified which fuse operated the keyless go, removed and replaced it, and it worked fine. It happened about three or four times in the life of the car, which was annoying, but the above cure always worked. (Indeed, I even kept a couple of spare 5 Amp fuses in the car in case I dropped one in the ridiculously inaccessible fusebox). You'd no doubt get the same result by disconnecting the battery, but that might cause you other inconvenience having to re-set things. |
Thanks, I will try that. |
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
I had a similar problem , caused by myself, removing and reconnecting a fuse which |
| All times are GMT |
