![]() | Home > General > My very first test drive of an RRS.. |
HappyHammer Member Since: 24 Jan 2017 Location: Essex Posts: 59 ![]() ![]() ![]() |
My first test drive coming up..5L Supercharged
delta351 Member Since: 10 Jan 2017 Location: Fareham Posts: 84 ![]() ![]() ![]() |
Make sure it comes with a petrol station |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2020 ![]() ![]() |
Warning: the link shows your postcode... |
Ahhh, yes.
Scrumpy...
Looks like someone change the standard wheel center caps from the standard silver sparkle finsh ones to the bright silver finish ones. I did this when I fitted Diamond Cut alloys as matched wheel better. For some reason the have used the green embosed ones, only as Scrumpy said S/C sould be black and silver.
S/c? |
Supercharged! Doh |
S/C = Supercharged |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 426 ![]() ![]() |
I would of loved a supercharged RRS BUT couldn't justify the fuel cost so bought a SDV6 but still love that V8 noise when I see one going down the road. 2019 4.4 SDV8 Autobiography Velocity blue.
On A good Day, you should see it on a bad day. |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 ![]() ![]() ![]() |
Always wondered why they put it in MPG specially if your speedo is in Km/h, surely it should be KmG? Just a thought |
nigethecat Member Since: 22 Sep 2016 Location: Aberdeenshire Posts: 115 ![]() ![]() ![]() |
Should be litres per 100 km - lower figure the better ! (maybe it is showing litres per 100km that would mean an SC was doing 48mpg .... probably not even with the engine switched off |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
i think you can select the units in a set-up menu somewhere |
