![]() | Home > Faults & Fixes > park brake fault |
Mpg could of increased because the park brake is binding. Do the rear wheels feel hot after a journey ? If you have warning lights coming on then the hand brake needs checking anyhow. 2008 G4 RRSport TDV8 current
Does sound like binding rear breaks can you smell anything |
rostan242@gmail.com Member Since: 15 Sep 2016 Location: Alfreton Posts: 28 ![]() ![]() ![]() |
Check it out when I come back from work but this is an important clue
I checked, and unfortunately nothing smelled and did not block took off my drum,everything looks ok
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2016 ![]() ![]() |
Find a good independent LR mechanic.....
probably I will have no choice
Bodsy or Flack will sort it for you
problem finded by delphi fault code U0417 Invalid data received from parking brake control module
Have a look here last post on the page will give you a starting point as you appear to have a wiring issue |
problem found. cracked tape in inside the brake module
Tape? Intrigued |
