Home > General > what are the common problems with the 4.2 sc engines
steve.rrs
hi i have a 2005 rrs with the 4.2 sc engine, just wondering what are the common problems i could expect on this car
Post #519784 Fri Mar 03 2017 9:57pm
Scrumpy
I have the same car as you and from what I can tell, these engines are pretty good so long as they are serviced regularly.
It's the other bits we have to worry about!
I'm happy to stand corrected if anyone else thinks differently. 2016 RRS SVR Estoril Blue
Post #520720 Mon Mar 13 2017 12:51am
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
The petrol injectors clog up 2007 SUPERCHARGED HST
Post #520727 Mon Mar 13 2017 8:32am
TheWojtek
High-mileage 4.2 SC (as well as 4.4) can have issues with the timing chain, tensioners and guides. This is easily spotted by listening for 'clunking' noise on idle and - inevitably - check engine light with codes for "bank 1 and 2 lean".
It's the less catastrophic version of the 5.0 (SC) timing bolt issue. The bolts in the 4.2 and 4.4 are 6mm and they tend to bend slightly, which leads to the guides getting out of adjustment (or not 'guiding' at all), which leads to chain slack, which leads to valves opening and closing not in sync with the piston movement (hence the 'lean' codes).
The cure is to get a a complete timing chain kit along with guides and two new chains. Costs roughly $600 + fitting. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #520729 Mon Mar 13 2017 9:17am
