| RRSPORT.CO.UK | ||
|  | Home > Technical > Dreaded suspension fault |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | It could be a few things, most likely is a height sensor isn't right (check the 4x4 info and see if one wheel is showing as being high/low), another posability is that the steering angle sensor is out of alignment.
|  Thu Mar 09 2017 8:48am |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | 4 x 4 screen shows all sensors ok and none of them flashing red and diagnostics was plugged in like I said in the above post and no faults stored   | ||
|  Thu Mar 09 2017 10:07am |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | Sorry, I hadn't read your post properly and missed that no codes are stored.   | ||
|  Thu Mar 09 2017 10:15am |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | just checked the 4x4 screen and all the height are displaying the same in all 3 height settings.
|  Thu Mar 09 2017 10:23am |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | Is the car sat on level ground and is the car itself sat level (measure from tyre to wheel arch) ?
|  Thu Mar 09 2017 11:08am |
| B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420      | The car is on level ground and all the tyre to wheel arch measurements measure the same height whichever height setting it is on.
|  Thu Mar 09 2017 12:33pm |
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594      | your local indy will be able to sort it for you (if it is the problem)   | ||
|  Thu Mar 09 2017 1:04pm |
| Posting Rules
