Home > Technical > Adaptive Dynamics fault - REAR
Julianp
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Baltic Blue
Hi
I've got a 2012 RRS SDV6 HSE Lux with the adaptive dynamics. I know it has AD, because it's telling me it has a fault with it!
The NSR upper arm was replaced last week, and now there is a dashboard warning "ADAPTIVE DYNAMICS WARNING". The warning is constant and the suspension does feel like its locked in iron girder mode. A couple of diagnostic codes come up:
U043A - Air Suspension ECU Faulty Signal, and
C110E - N/S/R Solenoid valve shock absorber.
The sir suspension compressor was replaced last year. From looking on line I can see many references to AD faults at the front, all caused by a wiring fault, and easily found and fixed, because the sensor sits on top of the shock mount, but I can't find any information on the same for the rear. I'm wondering if maybe a wire or connector has been knocked by changing the arm, but I have no idea where the sensor sits at the rear.
Does anyone have any information on this, or know of any links or anything at all really? I can't get it into LR for a couple of weeks, so I'm just trying to get a feel for where the issue might be.
Julian
Post #520238 Tue Mar 07 2017 8:05pm
DrRob
Can't help but these guys come recommended
http://www.ultimate4x4specialists.co.uk
http://alltrack4x4.com
Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #520240 Tue Mar 07 2017 8:16pm
Socast
Re: Adaptive Dynamics fault - REAR
Julianp wrote:
Hi
Julian
Having the NSR upper arm replaced and then you've got a warning that states the NSR solenoid on the shock isn't right I would suggest that whoever replaced the arm needs to fix it. It'll either be a nipped wire or disturbed plug.
The AD Warning will be caused by this fault, the ECU signal might just be a blip, clear the faults and see if it comes back.
Post #520310 Wed Mar 08 2017 10:11am
Julianp
Thanks for those DrRob - I'll take a look at both. Dudley is pretty close.
And yep, Soscast, that's what it feels like to me. LR had the standard 3 week booking time if you want a courtesy car, so I used a garage local to me for the MOT, and had them do the arm at the same time. I was hoping to give them a clue where to look for anything that might have been damaged in the process, so they could have another look.
Julian
Post #520334 Wed Mar 08 2017 3:58pm
DrRob
4 wheel alignment will need doing too after changing any suspension arms * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #520343 Wed Mar 08 2017 4:40pm
Julianp
Yep - it was booked in, but I cancelled in case it all has to come back off and then had to be done again. I'm sure it won't, but it just seemed prudent until the AD issues is sorted. I'm doing 10 miles a day at the moment, (the joys of local contracts!), so not doing too much damage to the tyres.
Post #520348 Wed Mar 08 2017 6:13pm
