![]() | Home > General > Another problem just raised its ugly head!! |
| danboy Member Since: 20 Dec 2016 Location: st neots Posts: 27
Hi Guys
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
Is it the complete tail gate, or just the top hatch?
hi,
at the moment its the whole tailgate 2007 RRS HSE |
Well, that's my theory of tailgate switch malfunction.
cheers dan, ill have a look tomorrow.
The switch from the upper tailgate is 5 minutes to get out, but you need the top hatch open. 2 ways, 1 you can either use a flat blade small screw driver and push it in and prise it out(there is spring tabs either side) but these can break. Or look underneath on the inside there's 8 t20 screws that you remove then the trim on the outside can be slid up and off, exposing the rear window beam and switch, from there it's a simple push out. |
ok ill give it a go, whats troubling me though is that its the whole tailgate not just the top window. ill have a look anyway.
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5136
Do you have a sunroof. |
Hi Andy. No mate. No sunroof. Went out this morning and sure enough the tailgate
| Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594
Try doing a soft reset of the car (disconnect the battery leads and then touch them together, this purges all residual power in all the systems).
