![]() | Home > Technical > HELP!!!! Can't turn engine off, even when key removed! |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
Park it somewhere sensible.
| Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567
Thanks Andy K.
If you can't stop the engine remove it and see what happens. |
I wouldn't suggest pulling anything while the engine is running. You may inadvertently cause a voltage spike to an ECU, which will cause you an even bigger headache than you already have... |
So how does one stop the engine ? And locate the fault |
Thanks for your replies.
| sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131
What a nightmare.... out of curiosity did you get is fixed? '06 RRS Supercharged Cairns Blue |
not fixed yet sonnyjim,
| DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264
Sorry to hear of your problems Scrumpy
Thanks Devon, at least I got it home today. Cleaned up the contact on the starter relay and left the battery disconnected overnight (otherwise everything stays on). Reconnected the battery this morning and the amber Parking Light had gone but the airbag light was on. Thought it might have reset itself, drove home ok but still can't turn it off with the key.
So the car has been into my local indy and they have run the diagnostics.
| Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378
I'm gutted and glad for you. But hey at least the fault is found now, but ouch!. |
For future reference, a 2nd hand BCM cannot be reconfigured. It must be matched with the the PCM to enable/disable the immobiliser |
Thanks Disco_Mikey, that puts my mind at rest with what the local indy has told me despite conflicting info on the net. 2016 RRS SVR Estoril Blue
| All times are GMT |
