![]() | Home > Maintenance & Modifications > Steering/front suspension jumping |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 954 ![]() ![]() ![]() |
IMHO I would change the complete arms as quite frequently the originals have to be cut off due to the bolts being sized.
robertevans68 Member Since: 28 Jan 2015 Location: Cheshire Posts: 5 ![]() ![]() ![]() |
Ok thanks, there's no banging or knocking at the minute so I'm going to try and last until better weather 😀 |
If you drive very slowly and dab on the brakes you should hear knock,, a sign that the front lower arms / bushes are worn. Might also be worth having a good look at the wheel bearings while your busy as these don't last forever either
