![]() | Home > Faults & Fixes > ABS warning lights all on |
Suthy Member Since: 09 Nov 2015 Location: Oxford Posts: 12 ![]() ![]() ![]() |
Ok, I have now replaced the rear left speed sensor as this wasn't showing any speed when moving whilst my reader was connected, This made no difference.
Ok, after getting the workshop manuals from Naks, I have traced the wiring looms, tested for continuity between the wiring sensor connector C0502 and the front connector C2294T, and have found a break in the white cable, as there are no connectors in between these points I will have to run another cable to replace the broken one, I will run a temporary one first just to double check my findings. |
All sorted, ran a new cable in between the 2 connectors and wired up, all yellow warning lights are now off.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1548 ![]() ![]() ![]() |
Well done for your perseverance. |
