![]() | Home > Technical > Using aux on my rrs 2006 |
nigethecat Member Since: 22 Sep 2016 Location: Aberdeenshire Posts: 115 ![]() ![]() ![]() |
Hi Stumpdok and welcome !
Stumpydok Member Since: 27 Feb 2017 Location: Cornwall Posts: 13 ![]() ![]() ![]() |
plugged in the same but wont work ,only my laptop will work |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5043 ![]() ![]() ![]() |
Volumes need to be high |
Have you tried a different aux cable? If the laptop is working then the connections sound ok but worth checking.. when playing from laptop are up you using WMP or iTunes? Never tried to play music via my iPhone as I think this would mean I was unable to access the Bluetooth phone function once aux is connected. D3 LHD - great car !
yes i have .just dont know why its not working. i have know idea what format they are ,or supposed to be tho.[/url] |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
I have my iPhone plugged into the aux port, playing Spotify. When I use the Bluetooth for calls, it pauses the audio. I don't think it starts playing again when the call ends thou.
Ok thanks will try that. |
Tested this more today, if my iPhone is playing when I take a call, it resumes the music after I hang up |
flindersstation Member Since: 02 Jan 2019 Location: Scottish Highlands Posts: 17 ![]() ![]() ![]() |
I've tried two cables with my iPod and the sound is barely audible. Suspect a bluetooth extender will be the same. I'm going to burn some CD's as that is working a treat! |
You can use a headphone amp to step up the gain between your device and the aux input which will up the volume but be careful not to overload the input (you would know as it will sound horrendous). I do on my 2012 sometimes. |
The volume on the iPod needs to be turned right up - the max you can without distortion then control the volume from the radio. 07MY RRS TDV6
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Not sure if this helps but I had the same problem on my 2005 RRS. I was trying to play an iPod (160Gb classic) through the aux port in the car using a 3.5mm jack from the headphone socket on the iPod but the volume was rubbish.
you got a link to that cable scrumpy? or lightening equivalent ? |
Andy, I just used something like this
