Home > General > EGR valves again
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
EGR valves again
Chaps, I posted about the Restricted Performance red triangle which was diagnosed by RAC as EGR valves about 2 weeks ago. Since then the red triangle and Restricted performance (and also the amber engine icon) have been coming up on the dash 75% of the time, and ACTUAL slight hesitation on acceleration has only very occasionally happened. However, I'm booked in this Wednesday for the garage (non JLR but very good on RRS) to strip down and look at them. With it being a TDV8 the strip down is considerable, so if I am called on Wednesday to say they are all coked and a clean will do it, do I ask them to change them nonetheless? What is the cost of the parts? Bearing in mind the strip down will be fairly costly in labour do I go whole hog? I'm getting no white smoke or complete stops (yet).
Post #519166 Mon Feb 27 2017 4:08pm
Socast
Wouldn't it be just as cheap to have them removed and re-map the engine, they can't go wrong again then.. Thumbs Up
Post #519169 Mon Feb 27 2017 4:14pm
DrRob
I thought TDV8 EGRs couldn't be removed....? Unlike TDV6 ones which can be.
Remove old ones. Fit new ones from Advanced Factors (forum discount). I would not refit the old ones despite any "assurances"
http://www.advancedfactors.co.uk/ * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #519171 Mon Feb 27 2017 4:18pm
Socast
I'm not 100%, but I thought the v6 could be removed and that was that, but the tdv8 had to be re-mapped. Happy to be corrected if I'm wrong.
Post #519172 Mon Feb 27 2017 4:22pm
DrRob
I'd be asking Bodsy/Flack/Geoff. / Alive / BAS etc etc for absolute clarity Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #519175 Mon Feb 27 2017 4:40pm
Timf
Thanks all. Dr Rob that's a handy site. The 3.6 EGR's are £250... Evil or Very Mad In words of two syllables what does a re-map do Embarassed
Post #519176 Mon Feb 27 2017 4:40pm
Socast
Tells the engine that it doesn't need the egr valves to run properly.
Post #519177 Mon Feb 27 2017 4:42pm
Timf
Thanks Socast...I agree it would be the way to go. I will speak to the garage Thumbs Up
Post #519178 Mon Feb 27 2017 4:52pm
