Home > General > Vibration question
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Vibration question
I've noticed slight vibration from my tdv8 when I accelerate hard , especially when accelerating when example leaving a roundabout , seems to be front end as if whole front end is rumbling / vibration sensation ? I am wondering if this points towards wishbones or steering column as I've been considering having wishbones replaced for a while now . Recently took a discovery 4 out for a spin that had recently had wishbones replaced and the whole ride experience was fantasticly smooth and the car just seemed to glide beautifully , but could this be because it's not so harsh as my rrs suspension , any thoughts welcome
Post #519062 Sun Feb 26 2017 6:25pm
DrRob
Have you checked the bushes are worn? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #519063 Sun Feb 26 2017 6:37pm
Alfie
Hi , what would be the best way of checking this Dr rob , generally speaking the car seems to drive fine on most roads but you notice a solid thump when going over rough road surfaces which I had put down to sports suspension being firm , but since driving the disco 4 the ride quality is so much better in the discovery , steering seems more refined as well
Post #519068 Sun Feb 26 2017 6:54pm
Eaters
This could well be a bushes issue but if you have larger wheels and low profile tyres compared to the disco then this will give you a harsher ride over the crap potholed roads we see these days.
My suspension noise problems over the last 6 months have been largely cured by a new lower front wishbone and 2 new wheel bearings. To test for the wheel bearings, drive at low speed and turn the steering wheel. If you get a graunching sound it's probably a front bearing. Rear bearings can be heard again at low speed trundling away. Your back seat passenger should be able to tell you which side. Your local Indie should be able to help confirm such a diagnosis.
Get this sorted before you start looking for the vibration issue as it may solve both your problems Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #519070 Sun Feb 26 2017 7:08pm
Alfie
Wheels on my tdv8 are standard 20 inch rims running on 275/45/20 I opted to putting 45 profile to help with ride which definately improved things last summer , I have checked both front wheel bearings by jacking up each corner and checking for any play and found nothing , I suspect wishbone bushing being the culprits as my car has covered 95000 miles and I have no history of either being replaced at any stage
Post #519072 Sun Feb 26 2017 7:48pm
Olly-ibiza
I changed the front arms on mine last time i had the body off, it was like driving a different car! spiteful Range Rover Sport tdv8
Post #519073 Sun Feb 26 2017 8:21pm
DrRob
Perhaps take it to an independent LR specialist for their assessment?
Nene Overland is nr Peterborough. Must be others if you do a search on here or Disco3 sister forum....
Worn bushes will make the car thud over bumps * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #519074 Sun Feb 26 2017 8:22pm
gogsy1956
As olly said, I changed the front lower arms on mine and also did wheel bearings the same time as I could hear a rumble when going round right hand bends. It was like Frizington a new car when they had been done. If yours is on 95k they must be ready for replacement by now.
If you drive very slowly and dab the brakes you will hear a clunk if the arms need replacing. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #519113 Mon Feb 27 2017 4:41am
gogsy1956
Don't know where Frizington came from!!!!! Should be driving Rolling with laughter 2010 RRS, TDV8
22" overfinch
Post #519114 Mon Feb 27 2017 4:42am
