Home > General > Dynamic Response System Filter Change - Loose Access Bolt
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I did a DSC fluid and filter change on my 2010 TDV8 last week and to my amazement I found the big nut which gives you access to the filter in the DSC valve block was only hand tight. It is supposed to be torqued to 62Nm. There has been no reason for my local dealer to touch this item so it must have been like this since new ( I am the original owner). The nut requires a 38mm socket so it cant be undone unless you really want to do so. Could this be another Landrover quality issue.
Post #502701 Sat Aug 13 2016 7:18am
DrRob
How often should this filter and/or fluid be changed?
Schedule says every 5 years or 75K but local dealer does it "on advisory only"??? * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #518593 Wed Feb 22 2017 2:19pm
Meiang
On my old Discovery 2 I changed the ACE fluid and filter every 2 years. Its probably over the top but in the 9 years that I owned the vehicle no issues were ever forthcoming.
The DSC system is worked quite hard so it makes good sense to keep it in tip top shape. The cost of repairs is not worth thinking about.
Post #519018 Sun Feb 26 2017 10:50am
That's an interesting statistic.
If it comes out dirty they your doing the correct thing
Post #519023 Sun Feb 26 2017 11:33am
