Home > General > Servicing friends RR Sport - advice please
Page 2 of 3 <123>
SRE
Spain
Andy K. Good point, the 2.7 filter if not located correctly can, sorry WILL wreck the engine. Plus the filter does not simply drop out.
Google 303-1128 OIL FILTER REMOVER
Best take the car to someone who knows what they are doing Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518812 Fri Feb 24 2017 2:29pm
or gain knowledge before starting from those that know.
maybe an internet forum.....
Post #518813 Fri Feb 24 2017 2:34pm
SRE
Spain
Andy is correct Bow down
But for starters
http://www.disco4.com/forum/topic106051.html?
Also think about how you reset the service indicator etc. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518814 Fri Feb 24 2017 2:38pm
SRE
Spain
Sorry, you only need 303-1128 OIL FILTER REMOVER on the 2.7/
But you do need to reset the oil leval In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518815 Fri Feb 24 2017 2:41pm
SRE
Spain
Read this.
http://www.disco4.com/forum/topic139151.html?highlight=reset+oil In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518816 Fri Feb 24 2017 2:46pm
m3nutter
England 2007 Range Rover Sport TDV6 HSE Zermatt Silver
Andy K wrote:
One thing no one mentioned is the oil filter. I assume its the same design as the 2.7 ?
1. You need a large socket to undo. ?
2. You need to fit the seal into the groove on the housing.
3. Most important, put filter on the car first, locate the filter nipple back into the hole on the car.
It's very important you do this, otherwise it can wreck the engine.
Put surround back on the tighten up till it stops. No need to tighten further.
And If it's in off road mode to get the sheild off and the sump plug, you need a box to stand on to reach the filter unless your 7 ft tall... Laughing
Post #518855 Fri Feb 24 2017 9:25pm
Good point
Post #518859 Fri Feb 24 2017 9:59pm
riverblanche
Hi and welcome Thumbs Up
May be worth you having a go with the search tab in the orange banner above, loads of stuff for you there
search for "pollen filter" and if it looks like Alans in "Vermin attack" its time to change it Laughing
30 second job to have a look at it order from AF in the sponsors section then another 30 seconds to fit it when it arrives
hope you get better than my "mates rates" did the niece's rear brakes and it turned out I got 25p/hour Laughing
Post #518866 Fri Feb 24 2017 10:31pm
m3nutter
I've done better than that and got "a mug of tea" per hour Very Happy
Post #518901 Sat Feb 25 2017 9:08am
SRE
Spain
Can we ask for an update :?:
justanewbie
I assume you've done the job by now Question
How did you get on Question In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #518939 Sat Feb 25 2017 2:03pm
justanewbie
Thanks for all the tips guys.
Not started it yet - going to order the parts next week and hopefully sort it in the next week or so. I will report back Thumbs Up
I am not making any money off this, it's for a friend and I'm a nice chap Cool
Post #518973 Sat Feb 25 2017 9:41pm
ragpicker
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Sumatra Black
Good on you justanewbie Thumbs Up
The only absolute thing to make sure is that the oil filter is replaced correctly. Everything else is undoing nuts and bolts and replacing parts. Servicing is not rocket science and if you're handy enough around an engine then I'm sure with a point in the right direction you'll be fine.
FWIW I service all my cars, always have. This includes our RRS and my porsches (apart from my turbo which gets a stamp every year because 911 turbo folk are a peculiar breed). I've never had a problem selling any cars because the invoices linked to the service schedule and photos of the process are far better than a stamp in a book. Any old codger can cut up a potato and put a stamp in.
If you don't have the car in front of you and haven't done it before then you aren't going to know immediately what to do, even if you've been a mechanic all your life in a small garage. Asking for help is better than cocking it up IMO.
I don't often contribute on here but do check in regularly and would like to see how you get on.
Post #518977 Sat Feb 25 2017 10:18pm
SRE
Spain
Remember.
Service Reset
Oil counter reset - Sorry if teaching granny to suck eggs, Embarassed however I assume you understand DPF's and how they work plus how they dilute the engine oil thus impacting the oil level and quality.. The oil counter calculates the this, also partial cycles/interrupted/regeneration not completed. If the oil counter reset is not done then you will not be able to read the correct oil level.
Also ensure you only use the correct oil, DPF vehicles use a different oil than non DPF vehicles. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #519046 Sun Feb 26 2017 2:25pm
SRE
Spain
Status Report
Any update on this, after all it is dragging on a tad. Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #519722 Fri Mar 03 2017 3:26pm
justanewbie
Completed the service today.
'Hardest' part was the under tray bolts had been put on so tight that I need a breaker bar and some heat to take them off. Also, one bolt was rounded.
Fuel filter was a bit fiddly.
I cannot see a 'service required' message on the dashboard/screen - what does it look like? In any case, been referred to a friend of a friend who has the relevant diagnostic kit to reset the service message/interval.
I noticed that all 4 tyres are wearing on the inside so I might start with tracking the vehicle first. Also, front brake pads need doing so will sort all this and then put it in for MOT and my good deeds are done.
Post #520242 Tue Mar 07 2017 8:24pm
Page 2 of 3 <123>
