![]() | Home > General > 2010 RR Supercharged Autobiography spare wheel nicked |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
It has happened to a few of us on here - I even recorded the |
robinfbrown Member Since: 09 Oct 2015 Location: London Posts: 3 ![]() ![]() ![]() |
thank you very much for taking the time to reply, i am grateful i still have the car to be honest !
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 ![]() ![]() ![]() |
They're not steel wheels but a smaller alloy.
If I'm honest the spare wheel that I replaced was used & cheaper than a new steel spare wheel. If you do end up with a steel spare - look for a one off that matches your other 4. I appreciate its a cost that you shouldn't be liable for - was there any excess - I repaired - replaced mine for about £400 which included a newer anti theft winch ( these are cut by the robbing |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Mine has a steel space saver spare. I had my iron monger make a steel tubes to cover the chain cost nearly nothing and is now safe. And yes these space savers dogged nicked as well. SVR 2018 in Santorini Black. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5093 ![]() ![]() ![]() |
Excellent point. If you go through this link you can get the build sheet http://www.vindecoderz.com/EN/Land%20Rover...call/81058 |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1054 ![]() ![]() ![]() |
Whereabouts in London?
I have a full sized spare fitted with 275/45 20 which is slightly bigger than the 40 no problem also secured with an RLD protector 2008 G4 RRSport TDV8 current
